Results 1 to 7 of 7
Thread: Solar Cover Puller
    Solar Cover Puller
    Hey folks,
    Do they make a solar cover puller? Something to make it easier for 1 person to put the cover back on? I'm thinking something that looks like a long bar that attaches to the end of your cover and has a string on each end that meets in the center. Please see my crude drawing below as that best explains it. Do they make anything like this or anything at all to make it easier for 1 person to get it back on?
    Thanks
    **EDIT: He's not flying a kite or waving a flag. He's pulling the cover back on. One day my art will be appreciated.
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Solar Cover Puller
    The Solar Roller Coverstick
    http://solarfactory.com/
    No idea if they are any good.
    Quote Originally Posted by cramar
    Thanks...that's more of a solar reel though, designed for pools that can't support a traditional solar reel. I have a solar reel and it makes taking it off easy. Getting it back on is easier with it, but it's still difficult for 1 person. You have to run back and forth to each side of the pool. I don't have a problem with it, but when I'm at work and my wife is alone with our 7 month old, it's a bigger deal, which is why I'm trying to solve it. Thanks for the help though
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If they make an adhesive that can glue the solar cover back onto itself, you could glue in a piece of capped PVC (which would float) by folding the cover back over itself a little bit with PVC inside. Then just attache a rope to either end like your drawing. 18ft long piece of PVC would flex some however. So if you added a rope in the middle as well it should all be good. You'd eat up some of your solar cover gluing in the pipe.....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Yeah, I can definitely build it myself. I just kind of assumed something must be out there already, but maybe not.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Quote Originally Posted by NullQwerty
    I appreciate it.....along with the comment it made me chuckle so hard I almost woke the little one up.
    Quote Originally Posted by Leebo
    ha
