Results 1 to 8 of 8
Thread: Skimmer plug removal
    Apr 2012
    South Dakota
    87
    Trying to remove the skimmer plug and am having difficulty. Any idea on what tool I could use to remove it? The pool company the closed the pool used a PVC pipe and I tried 1 1/4 but the walls are too thin and bend when I twist and 1 1/2 is too big.
    Included a picture of a extra plug I have.
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Skimmer plug removal
    putty knife?
    Apr 2012
    South Dakota
    87
    Tried a putty knife
    Vinyl liner
    Taylor K-2006
    11,969
    Can you post a pic of the plug IN the skimmer?
    Apr 2012
    South Dakota
    87
    Picture of plug installed.
    Vinyl liner
    Taylor K-2006
    11,969
    So that entire assembly won't come out? That looks like a non-threaded cap that may have been glued on a fitting that should have a threaded end going into the hole. Totally guessing here - hard to tell from pic.
    Apr 2012
    South Dakota
    87
    I will grab a hold of the PVC pipe and not the plug and see what happens.
    Vinyl liner
    Taylor K-2006
    Apr 2012
    South Dakota
    87
    Grabbed the PVC assembly and it will not budge. I was a little slimy though. I will have to call the pool company to have them come out. I need to have them come out and fix the weir because it sticks and I can't figure out to remove it too.
    Vinyl liner
    Taylor K-2006
