Results 1 to 8 of 8
Thread: Water spitting out of the top of sand filter?
    Hey everybody. I just bought my first house and it has a pool.
    I pulled the cover off on saturday and shocked the pool and thought I was running the filter. It was running but I still had a plug in the skimmer basket. so Today I removed that plug and started up the filter again, it runs for about 30 seconds before water starts squirting out of the pressure relief valve on my hayward S200 sand filter. So as of right now the filter is off until I can get this figured out. I looked around the pool for returns thinking I still had them covered but I think there is only one and it is uncovered.
    Any ideas?
    38,305
    Re: Water spitting out of the top of sand filter?
    Welcome to TFP!!!
    Are you sure it is a pressure relief valve and not the air bleed that just needs to be closed?
    Make sure you read Pool School (button at the upper right of the page) so that you understand the correct shock PROCESS.
    it is a manual air relief cap, does it need to be closed? if so what is the highest pressure should I let the pump gauge go to before backwashing?
    38,305
    Yes, you close it when the pump is running and water starts squirting out so that you know you got the air out.
    You should backwash when the pressure goes up 20-25% of your clean pressure ... what is your clean pressure? Does the gauge read zero when the pump is off?
    the gauge reads zero when the pump is off, but I dont know what the clean pressure is
    38,305
    So do a thorough backwashing and then see what the pressure is when you start on filter again.
    Awesome. sounds like a plan. Thank you!
    38,305
    If you have never done it before, this post describes a way to "deep-clean" and resettle the sand. This really should be done every year or so:
    my-sand-is-channeled-how-to-fix-it-t7626.html#p60821
