Thread: Valve reversed after startup...?
    Aug 2011
    Northville, Mi
    312
    So, everything is running and my water looks far better than I expected after getting everything started today. The weird thing is though that my deck jet valve actuator seems to be reversed now. When that circuit is "On" (in my ET4) the valve has the jets completely off and when it is off, the jets are running. I don't know how that happens other than switching the wires, which didn't happen. Anyone have any ideas on what could make this happen and how I put it back to "normal"?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    38,475
    Re: Valve reversed after startup...?
    There is a switch on the actuator itself ... flip it to the other side to reverse the polarity.
    Aug 2011
    Northville, Mi
    312
    Thanks Jason - I *totally* forgot about that switch (it's actually "underneath" mine, so you can't see it). Still can't quite figure how it got switched, but all is good now.
