Thread: Automatic PH Solution
    Well I have the Autopilot SWG, and wish I paid attention that the Total Control Solution can't be integrated unless I buy the other Power Unit. So since I am not doing that.
    I want to have something that Monitors the PH Level and Injects the Muriatic Acid automatically.
    What are some of the well known ones used.
    I have a Plaster Pool.
    40,000 gallons.
    AutoPilot SWG.
    Pentair VS Pump.
    Thanks.
    Re: Automatic PH Solution
    Any Suggestions?
    Looking to place an order today.
    I was looking at
    ISIPOOL pH from Aqua Water Systems
    pH TEK System
    Hayward HCC 1000
    mas985's Avatar
    Pleasanton, CA
    11,737
    So why aren't you going with the Autopilot solution?
    Mark
    Quote Originally Posted by mas985
    Was told that unless you order the Total Control Solution as a Package you can't upgrade or retrofit it.
    I just spent the money on the new System, and don't want to have to purchase a new Dig220 all over again to go with the Total Control.
    The Dig-220 in the Total Control package has a different power supply. I called Autopilot yesterday,
    mas985's Avatar
    Pleasanton, CA
    11,737
    You might want to read through this thread:
    can-i-add-the-ph-control-option-to-my-autopilot-t4758.html
    Mark
