Results 1 to 9 of 9
Thread: Could you test CYA in complete darkness with speedstir light
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    So i was testing CYA the other day, but had no sunlight, and i was thinking oh well i'll test anyways see what i get. Then i started wondering why sunlight, back to it, waist high and took my speed stir into the bathroom, put test tube with black dot on it turned off light and performed test in darkness except for speed stir light. I got the same reading i got outside (no sun).
    So if i wanted to, would performing the CYA test in darkness with the speed stir light give me more accurate readings over time as i'm eliminating some of the variable factors like sunlight, shading the tube etc.? Or not?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Re: Could you test CYA in complete darkness with speedstir l
    If your results are repeatable, I say why not?
    On a related note, I noticed if I stir my CYA reagent with the speedstir (putting the pill in the CYA mix bottle and letting it run for 30 seconds), my CYA reads about 10 PPM higher than if I just mixed the reagent by shaking the bottle.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
    I wonder if the +/- 10ppm on the CYA accuracy is directly related to our inability to thoroughly mix the CYA sample and reagent.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Apr 2013
    SoCal
    120
    So I tested harleysilo's idea out, by putting the CYA view tube on top of my speed stir with the light on. My opinion is that I do not trust this method of testing. I found that the black dot disappeared far sooner with the tube lit up from the bottom, than it does when I view the tube in daylight, as per the Extended Test Kit Directions.
    Matt
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I can't wait to try this with sun! Where is the sun!!!!
    18'x43' Sport Pool
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by thehowheels
    I haven't tried this yet, should be able to this weekend. I reviewed the extended instructions but found nothing that indicated the reading would be higher (less solution used) given a different lighting situation other than sun at back etc.
    18'x43' Sport Pool
    The light in the SpeedStir is nowhere near bright enough. You can do the test indoors with a daylight simulator lamp (very very bright) but they are fairly expensive.
    Mar 2007
    San Rafael, CA USA
    12,082
    The light needs to be indirect light and most of it will be coming in from the sides of the tube, not from the bottom. That is, the light needs to be diffuse coming in from all angles into the bottom, side and top of the tube. Plus, the speedstir light is not very bright.
    You can get reasonably close indoors if you have a lot of bright lights in the kitchen, for example. Kitchens are often the best lit larger areas in a house. When I turn on both the overall fluorescent lights in the kitchen and the more concentrated halogen bulbs that are over our island where the sink is located, then I get fairly close results to standing outdoors with my back to the sun though it is still consistently a bit higher in CYA reading by roughly 10 ppm. I do not stand directly under a lamp in the kitchen, but in between a pair of the lamps closer to one of them. Another possibly good indoor place is the master bathroom where there may also be good bright lighting.
    Outdoor indirect (i.e. shaded) light from a blue sky in the middle of the day is around 10,000-20,000 lux in intensity compared to around 100,000 lux for direct sunlight (reflecting on bright white snow, for example), but holding the tube in front of you cuts down some indirect light so is perhaps in the 5,000-10,000 lux range. Typical lighting in an office is on the order of 500 or so lux. The brighter kitchen and bathroom scenarios I described are on the order of 750-1000 lux overall.
    Lux is lumens per square meter so you can roughly calculate the illumination (illuminance) by dividing the lumens of the bulb by the area it is illuminating and more specifically this works well if you have multiple bulbs so can calculate an illuminated area per bulb (ignoring overlap). Divide this number by 2 to account for inefficiencies. In my kitchen, there are four 75W halogen at 1020 lumens each and the rough square area illuminated at counter height is about 9 square feet or 0.836 meters so this is 1020/0.836/2 = 610 lux. The fluorescent lights add to this, but probably less than half so perhaps I'm at around 800 lux.
    Though 800 sounds much smaller than 5,000, the visibility for contrast of seeing the black dot against a white background is a logarithmic effect (see this paper and this paper). If you have a particularly bright workspace with multiple high lumen lamps, then that will be closer to the outdoor indirect lighting.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I tried it, failed with a 20 ppm difference, inside reading was lower than proper reading!
    18'x43' Sport Pool
