Results 1 to 7 of 7
Thread: Should I put anything on the end of the backwash line?
    May 2013
    Sarasota,FL
    18
    So, I've decided that it's time to take the backwash line of my sand filter underground. Right now it empties about 12" above the ground and is right beside the pump. I'm wondering if that contributed to the motor failure we just had... Anyway, my question is once I put it the line underground, do I put anything on the end of it to prevent lizards, snakes, etc. from getting inside?
    14,0000 gallon, rectangle, in-ground pool with Pebblesheen finish. 1 hp Sta-Rite Dura-Glas pump and TA60 Tagelus sand filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Should I put anything on the end of the backwash line?
    I live in the country and mine tees into a 4" pipe that is open on the end. No issues with critters getting in the pipe.
    Oct 2012
    Central Ohio
    180
    They'll come out a whole lot faster than when they went in.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    38,528
    That is pretty much what I was thinking, there really is nowhere for them to go and they certainly won't be there for long after you turn on the backwash.
    May 2013
    Sarasota,FL
    18
    So you guys don't think they would be able to crawl up the pipe and into the filter and mess something up? I'm not too worried about them being in the pipe itself, my concern it about them somehow getting into the filter...
    38,528
    If they could get into the filter, the water would be coming out all the time.
    May 2013
    Sarasota,FL
    18
    Good point. Thanks!
