Thread: FC and pH
    FC and pH
    Can someone tell me if I have a false pH reading....My FC is 8.5 and my pH is 7. I've read that a high FC will give a false pH reading. I don't want to dump acid in the pool if not necessary and all I need to do is wait for the FC to go down to get an accurate pH reading, thank you, John
    16100 gallon rectangle pool built in 1984 including a 5' X 5'x 3' Spa, Diamond Brite in year 2000, Non-SWG Pool
    Re: FC and pH
    Correction, The pH is 7.8 not 7. Sorry, John
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: FC and pH
    FC over 10 ppm may give a false reading, so yours is fine.
