Results 1 to 9 of 9
Thread: HELP!!!
    May 2013
    North Central Texas
    4
    HELP!!!
    I recently bought a home with a pool. I've never had a pool in my life and don't know where to begin. The pool water is very green. I ran a leaf net across the bottom several times and am pucking up a lot of green " goop". Should I try to clear out the water first or should I try to clean out as much goop as I can while not being able to see it? I would like to avoid draining at all costs. I live in an area that is in the middle of a drought, and our current water restrictions do not allow for filling a swimming pool. Thank you in advance for your advice!!!
    27,000 gal in ground pool w/ vinyl liner, Pentair TA60D sand filter/flow rate 60, Hayward Super II 1 HP pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: HELP!!!
    Welcome to tfp, nodyesac
    You are at the right place, we have helped many people in your position and can help you as well.
    Poolschool (link near the upper right of each page) has tons of info that you will find helpful.
    Before doing anything, getting an appropriate test kit is very important and will make your clean up and subsecqant pool maintianing simple and as low cost as possible. See: http://www.troublefreepool.com/pool-...kit_comparison
    For now do you have any test results you can share with us? Tell us the source of the results as well.
    Until we have a good idea of your pools chemistry, it probably is good just to keep scooping blindly, since all the crude needs to come out eventually anyways.
    Here is a another poolschool article relevent to your situation: http://www.troublefreepool.com/pool-...efeating_algae
    Also, please review this poolschool article to help us get the information we need to help you: http://www.troublefreepool.com/pool-...efore_you_post
    May 2013
    North Central Texas
    4
    Re: HELP!!!
    I used an HtH 6 way test kit to get these results. I have ordered one of the recommended kits, but it has not arrived.
    Chlorine < .5ppm
    PH > 8.2
    Alkalinity 30 ppm as calcium carbonate
    Hardness 340 ppm as calcium carbonate
    CYA <30
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: HELP!!!
    You probably want to go ahead and address that pH since it could be WAY over 8.2 as that is the limit of the test range.
    You can use either muriatic acid or dry pool acid to lower the pH, but will need circulation while doing it, pool calculator can tell you how much, but it should be in the ballpark of 2 qt muriatic acid.
    Ike
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: HELP!!!
    You are going to need to backwash a lot during the process since you will filter a lot of gunk out. As stated, you want to start by lowering PH. If the pump works, run it on high. After an hour or two, retest the PH. If you are at around 7.5, you start shocking with bleach/liquid shock. Please read the links posted by linen to get the process. Make sure you keep an eye on the PSI on your filter during the whole process and backwash as needed. And yes, try to scoop as much stuff out as possible. You can start this process even before your new test kit arrives. The new test kit will make the shock part easier to manage and more reliable though.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    May 2013
    North Central Texas
    4
    Re: HELP!!!
    Thanks guys, the pool house and pump are on a different electric meter that hasn't been turned on yet. I won't be able to run the pump until Wednesday. Until then I'll just keep scooping away!
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: HELP!!!
    If you have a brush you can use that to stir the chemicals. However, since your pool is already green, I'd recommend just waiting. We recommend mixing in bleach with a brush when someone's water is clear but their pump will be out of service for a few days.
    May 2013
    North Central Texas
    4
    Re: HELP!!!
    Ok, I've been scooping and scooping. I got the PH down to 7.2. Should I start the shock process now? I backwashed the filter last night and it took quite a while to get the water semi-clear. There is still a bit of cloudiness to it. Should I do the deep clean of the sand (take off filter top, run water hose in sand) that I read about in another post first?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: HELP!!!
    Are you ready to test and monitor your pool possibly hourly for several days? Meaning are you off of work? Weekend is coming up! I don't think it would hurt to clean the sand filter and determine it has enough sand, but it may not be neccessary i don't really know.
    Here is an link to fixing a channeled sand filter my-sand-is-channeled-how-to-fix-it-t7626.html
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
