Results 1 to 16 of 16
Thread: My daughter is complaining that her eyes hurt after swimming
    May 2012
    Elk Grove, CA
    60
    I can't figure out why. Here are my numbers from today from my Taylor K-2006- I can't find anything wrong with them. This is an in-ground plaster pool with SWG:
    PH: 7.4
    FC: 9.8
    CC: 0
    TA: 70
    CH: 425
    CYA: somewhere around 40-50- like many others I struggle with this test
    Salt: ~3400
    I guess the FC is a tad high. I have very rarely measured any CC in the pool- I add a non-chlorine shock occasionally (maybe every 2 months) just in case. Should I dial down the SWG to get the FC closer to 5? Would that cause her eyes to burn?
    16k gal IG pool with SWG and DiamondBrite finish
    Pentair Intelliflo pump with 520 sq ft cartridge filter
    May 2012
    Elk Grove, CA
    60
    Re: My daughter is complaining that her eyes hurt after swim
    BTW- I overheard this conversation in the pool store yesterday when I was picking up some more acid:
    Pool store guy: "No, you don't want to mess with any drops or anything like that. The chemistry is really important with a vinyl pool so you need to stick with the test strips."
    When she says that her eyes hurt, what exactly is the complaint? Are her eyes red, itchy or burning? Is it pressure? How long does the irritation last?
    Is the water crystal clear?
    Also, is anyone else having similar complaints?
    Support the site
    May 2012
    Elk Grove, CA
    60
    Eyes turn red and are burning. Nobody else has really been complaining, but she swims a lot more than anybody else in the family.
    Water is crystal clear.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by cheezedawg
    Ok...now that that's out of the way, back to the serious part of the issue. Is she opening her eyes while she's under the water? If so, even with a good pH, eye irritation can still be an issue for some. A pair of swim goggles might be all that's needed.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    How old is she? I ask because my 3.5 and 6.5 year olds love their swim goggles. The 3.5 year old has recently taken up to using my snorkel and mask, yes he has a big head, they just barley fit, i need to get him his own set. They like being able to see clearly underwater for playing games and such. I know this is kinda masking the problem, if it's a problem of pool water vs. individual eye sensitivity.
    For me growing up as a kid, never using swim goggles, swimming in neighborhood pool, my eyes always burned after a long afternoon of sharks and minnows (requiring the underwater eye opening). It was one of those life lessons for me, if you keep your eyes open all the time they are gonna hurt later.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    30,427
    +1 on that advice.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I'm curious...what is the non-chlorine shock product you are using? In a properly maintained pool, any kind of "shock product" is unnecessary for the pool as well as your wallet.
    I would try lowering the FC a bit. Given a CYA of 50, the recommended FC maintenance range for a SWG pool is between 2 and 7. I would aim for the midpoint and see if that makes a difference to your daughter's eyes. Her eyes may simply be more sensitive than other members of the family.
    I recommend doing the CYA test in bright midday sunlight holding the CYA tube at waist level with your back to the sun. That is critical to getting a good reading.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Goggles are a good suggestion, you could try a higher pH, around 7.6 everyone's eyes are slightly different, but for the most part are around 7.5 I think opticians/ophthalmic surgeons can check this with a litmus paper type test if you want to investigate further to to make your pool pH similar to your daughters eyes, I doubt the chlorine level is any issue, but you never know, some eyes are more sensitive than others.
    Stuart Murray
    Scotland UK
    UK NPPOC
    May 2012
    Elk Grove, CA
    60
    She is 5. She does open her eyes a lot, but she did last year too and never complained. Not sure what is different. I can let the PH float up a little higher- can't let it get too high though with my CH levels.
    BTW, the non-chlorine shock that I put in a couple times a year is potassium peroxymonosulfate based. Just an oxidizing powder that I bought at the pool store to have in case I measure any CC. I put it in this year when I "opened" the pool because I thought I might have seen a slight color change when I added a drop of the R-0871 on the CC test, although I didn't really notice any pink or red when I added the R-0003. Like I said, it was just to make sure.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    cheezedawg:
    Potassium Monopersulfate (MPS)-based oxidizers can cause false positive CC readings, especially on DPD tests (which is different than the FAS-DPD test). It can also be an irritant, especially at high levels. I used to use this (and many other) chemicals before I switched to BBB. Now, no chemical go into the pool unless there is a specific need for it.
    Chem Geek provides a great explanation on MPS in this post:
    http://www.troublefreepool.com/dupon...monopersulfate
    Try raising the PH a bit, towards 7.7. Most people don't have issues until the PH is below 7.2, but that varies from person to person. She might be more sensitive to low PH than most.
    May 2012
    Elk Grove, CA
    60
    Thanks for the help!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Any feedback yet cheesy?
    18'x43' Sport Pool
    May 2012
    Elk Grove, CA
    60
    Not yet- between some colder weather and a stomach flu going through the house, there hasn't been much swimming. I am targeting a slightly higher PH (7.6-7.7) and I dialed back my SWG a tad, so we will see if that helps. We also got her a snorkel mask. I'll update once the kids get back out there.
    BTW- I remeasured my CYA yesterday in full sunlight waist high with my back to the sun (based on the recommendations here) and I got 60, so my FC wasn't as high as I thought.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    She's gonna love the snorkel mask!
    18'x43' Sport Pool
