Thread: Opening chemical balancing...
    First time opening the pool! I used the BBB method last year and it worked great. I pulled the winter cover off Saturday morning, washed everything, filled it up from the hose and got the pump running and dumped in the last part of a jug of 12%CL so I could get the jugs filled. After 24h I vacuumed it and the water looks pretty good to me! It's not totally clear, but I can easily count the ridges in the bottom drain and it is clear not green. +1 BBB.
    I did a full test today with the following results:
    FC: 3
    CC: 0
    TC: 3
    pH: 7.5
    T/A: 120
    CH:230
    CYA: 30
    Salt: 1800
    H2O Temp: 60deg
    I don't think I need to do a full shock cycle, as I don't have CC.
    My plan (in this order) is to: (via thepoolcalculator.com)
    1. add salt (~250lbs) then fine tune.
    2. add stabilizer to bring up CYA ~80oz to bring it to 60 then after it settles out, fine tune to 70.
    3. continue to add 12% liquid CL to keep FC between 3-5 until the water gets warm enough for the SWG to work.
    Do I have this about right? Just double checking - thanks.
    Josh S
    20.8k gal vinyl kidney; 600sqft surf area, Hayward 1HP Super; 300Lb Sand Filter; Aqua-Rite/T-9; RainbowRay LEDs, Jandy Deck Jets; and a whole 'lotta sweat n time...
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Opening chemical balancing...
    When your cya does go up to 60, and if the swg is not on yet, your FC level should be 5-9 ppm.
    Make sure you are confident that your salt is at 1800 ppm (I saw your other thread but did not have an answer) before adding...easy up, but its drain/refill to reduce.
    If you want, get a head start on combating the swg induced ph rise by working your TA down now using the aeration method.
    Quote Originally Posted by shep377
    If your water does not go crystal clear in a couple of days, I would raise it up to shock level and do an OCLT.
    30,403
    +1 what linen posted.
