Thread: Pump question
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Pump question
    Good day, getting closer to purchasing the house and I think I got a good price on a potential pool pump. Now the questions, if I live in a residential area with no woods and therefore little area to backwash would a cartridge filter be best? And would a Pentair FNS plus cartridge pool filter that was used on an above ground pool with a 2-speed 1.5HP Pentair dynamo motor work on a smaller gunite 17,000 gallon pool. Would $175 be a good price to pay for this used, I guess the cartridge is in good shape.
    Thanks so much
    rob
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump question
    Cartridge or a DE filter that you take apart to clean (as opposed to backflushing) may work best.
    For your 17000 gallon pool we would recommend as minimums 250 sq.ft. cartridge or a 46 sq. ft. DE filter.
    Post a model on the filter, you would want the FNSP48 or FNSP60 to meet the minimum posted above.
    For the pump, I am not sure about the dynamo line, specifically if it can handle the static head of pulling the water up from the pool to the pump, assuming the pump will be above the waterline. However if it is able to prime a igp, then the size should be fine assuming you do not have any high volume water features.
