Results 1 to 10 of 10
Thread: Borax and SWG
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Borax and SWG
    Hi guys,
    Do I use borax if I have a SWG pool?
    Steve-Liteguy
    13K Pebble-tech Pool, ECO pump, IntelliChlor SWG, DE
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Borax and SWG
    Sure. The pH buffering effects are particularly useful. I just borated a couple weeks ago and so far so good.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: Borax and SWG
    Quote Originally Posted by UN1017
    Ah Haa. Perhaps this will help with the acid usage. I've been dumping in a gallon per week just to keep it in check. How much borax did you use in your 15K pool?
    Steve-Liteguy
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Borax and SWG
    If your going to add borates it's easier if you use boric acid. The first year I did the Borax and acid route, the following year I did boric acid. Much easier. I've got a 17 K pool.
    Here's my story: boric-acid-the-easy-way-t38793.html?hilit=boric%20acid
    Poolcaculator.com will give you the answer.
    and according to the pool calculator: 55 lbs or 11.6 (76 oz) boxes of Borax would be needed to go from 0 to 50
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Borax and SWG
    Quote Originally Posted by Liteguy
    Borates are by no means required for a swg pool, but they can help. More importantly, what is your TA at?
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: Borax and SWG
    Great and thanks, Sorry for the dumb-a** question, should have gone directly to the pool calc
    Steve-Liteguy
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: Borax and SWG
    Quote Originally Posted by linen
    Untested as of today, just getting setup for the season, accidentally fell in and the pool was ball numbing cold for our climate here in AZ-My wife was laughing hysterically, dog too.
    Steve-Liteguy
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Borax and SWG
    Post you TA when you can take a break from the swimming For a swg TA really needs to be down in the 60-80 ppm range.
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: Borax and SWG
    thx sir, will do
    Steve-Liteguy
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: Borax and SWG
    TA today is 110
    Steve-Liteguy
