Results 1 to 9 of 9
Thread: Suggestions on my pool water
    Mar 2012
    Eagle, ID
    3
    TF100 results:
    FC 21ppm (was attempting to shock as water had very slight green tint upon opening 7 days ago)
    CC 1ppm
    TC 22ppm
    pH 8.2 (or off the chart)
    TA 18
    CH 880
    CYA well above 100
    Pool water is currently crystal clear. My refill water tests @ CH 100. I am thinking of draining and refilling to get a better handle on CH and CYA levels. If drain/re-fill recommended, do I need to wait for the chlorine level to go down before draining to my lawn?
    Thank you for your input,
    Philip
    Feb 2012
    Cypress, TX
    131
    Re: Suggestions on my pool water
    I wouldn't wait to drain. You are well under shock level for your CYA and it would be difficult to get there as it stands now. It's hard to tell what your PH really is because of the high CL causes problems with the test.
    For help with draining methods it would help to know the details of your pool. Inground? Plaster? Size? Part of the country? Etc...
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Eaglepool
    I agree with bluechip, I would do a drain/refill. Let us know what kind of pool you have. This is a very important question when needing to drain a lot of water (as you need to).
    Are you certain of your TA reading...are you certain you did not mean 180 ppm (18drops X10 ppm= 180 ppm TA)? It would be unlikely that you have that low TA and that high ph.
    [s:zz8k2q5l]Assuming that you TA is actually 180, you need to address ph soon, since 8.2 i high and levels higher than that also read as 8.2. If you are going to do a partial drain/refill in the next day I would wait on adjusting ph, but it will be longer I would adjust ph down to the 7.5-7.8 range now.[/s:zz8k2q5l]EDIT: oops...FC>10ppm, so ph should not be adjusted until FC is below 10 ppm...see following posts
    Apr 2013
    Phoenix AZ
    20
    Quote Originally Posted by linen
    Wouldn't that high of FC cause the pH test to be inaccurately reported as high? Meaning, he probably has pH lower than 8.2?
    ~20,000 gal in-ground plaster pool, 3/4 HP pump, ~3 sqft sand filter (newly replaced May 2013), TF-100 test kit with Speed Stir!
    38,285
    Quote Originally Posted by burine
    Correct, the pH will read falsly high when the FC > 10ppm
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Thank you burine, you are correct ....disregard my ph advice until FC is below 10 ppm
    Mar 2012
    Eagle, ID
    3
    Thanks for the input. My bad on the TA...should have been 180, not 18, as guessed. It is a plaster pool, ~18,000 gal. I have no groundwater issues to deal with. I am in Eagle, ID (I'll try to update my profile...thought it was in there already).
    Do you think the current chlorine level will damage my lawn if I drain it?
    Thanks!
    30,419
    No. It'll be fine.
    Mar 2012
    Eagle, ID
    3
    Thank you!
