Thread: New Automatic Cleaner
    Need Help
    I used to have a Polaris 360 for sometime after i bought the house. I used for about 1 year and it just stopped working and tried to get it fixed but it will cost more. I wanted to just buy another automatic pool cleaner. I went to the pool store yesterday and asked them for a replacement machine for the Polaris 360 and they said that since there is a suction side machine and there is no other machine that you can buy only the Polaris 360 or have to buy a robotic machine instead.
    I have oval shape pool with about 6 feet as the deepest side of the pool. We do have a lot of problems with dust and leaves that is main reason that I would like an automatic pool cleaner. I am willing to spend about $500 bucks on a machine on the expectation that he will last some time and that it will be saving me some time keeping the pool.
    DO you guys have any recommendations??? something within a budget, or just have to spend the money on a robotic?
    Thanks
    18K in-ground pool, Concrete, DE Filter
    jkurl's Avatar
    Fairfield, ca
    141
    Re: New Automatic Cleaner
    Quote Originally Posted by vickp85
    Need Help
    Thanks
    That doesn't make sense. The 360 is a pressure side cleaner. If you have a booster pump then you will need a pressure side cleaner. You can get another 360 for under $500 or the Polaris 280 for under $500 as well. If you want to catch the dirt I recommend the sand and silt bag which the model number is K14. I have a 280 and have not had an issue w/ it at all.
    Pool Size: 20 x 40 Free Form Inground Plaster Pool w/ a shallow cove.
    Gallons : ~23K Jandy CL580 Cartridge Filter, Jandy e-pump 1.5HP
    Polaris 280 w/ Booster Pump, AqualinkRS PDA4 Remote, Aqua-Pure SWG
    Jandy LED Pool Lights (2), Heliocol 500 Sq. Ft solar rack system
    Quote Originally Posted by jkurl
    Need Help
    Thanks
    Sent from my iPad using Tapatalk HD
    No I don't have a booster pump attached. It did not make sense when the pool store told me there is no other machine that could do what the 360 did. They asked if I had more than 1 skimmer becuase if I did then i could use a Baracuda.
    The whole topic of automatic cleaners confuse me.
    May 2013
    California
    46
    There are two other pressure side cleaners that I know of that will fit the 1 1/2" threaded wall fitting of the Polaris 360. One is the poolvergnuegen Pressure POOLCLEANER and the other is Kreepy Krauly Letro Legend II by Pentair. Neither require a booster pump. I would think you can fix the Polaris 360 yourself as there are only a few reasons it stops moving - the belts & the bearings are the usual suspects. I am going to say you can spend less $500 to get it moving again - way less. What exactly is it doing or is it just "dead in the water?"
