Does it have a float? You may want to adjust the float forward or backward to see if that affects it. I also had to take some weights off the tail of my Polaris. Apparently I had added a few every so often, thinking that would help it stay down but not realizing that when the tail is weighed down, the nose points up, so up it goes.
There is a part you can add to the tail that keeps it from flipping out of the water and spraying windows and bystanders. Heavy blue thing, forgot the name. If you add that, take a few weights off to compensate.
