Thread: polaris not staying underwater
    Got a brand new Polaris but it's popping up and swinging its tail around and squirting the windows which is annoying Mrs. CAF. Any idea how do encourage the little guy to stay down?
    CAF
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: polaris not staying underwater
    Nope. That's what they do. But you can carefully adjust the one jet on the back in an attempt to get it to stay down. Let me know if you get it to happen. You won't however
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Maybe take of the tail and see if it cleans to your satisfaction?
    18'x43' Sport Pool
    Does it have a float? You may want to adjust the float forward or backward to see if that affects it. I also had to take some weights off the tail of my Polaris. Apparently I had added a few every so often, thinking that would help it stay down but not realizing that when the tail is weighed down, the nose points up, so up it goes.
    There is a part you can add to the tail that keeps it from flipping out of the water and spraying windows and bystanders. Heavy blue thing, forgot the name. If you add that, take a few weights off to compensate.
    I adjusted the float and also there was a hex screw that maybe sets the amount of water coming thru the tail so I tightened that a bit. All seems good now. Thanks.
