Results 1 to 8 of 8
Thread: My pool thus far!!
    My pool thus far!!
    -First off thanks for all the help. This forum is wonderful and the people on this forum seem to be the nicest forum people i have ever seen!
    -Got my pool up today with pavers under each leg. I used a laser level.
    -Filling pool now.
    -I have everything hooked up. Sand pump (1600) and SWG system with coppper unplugged. Seems to be the smart thing to do. Don't really understand why intex would even have the copper in there.
    -At this point i have read so much and I'm feeling slightly overwhelmed. Tomorrow when the pool is filled I will do the pump operation per instruction manual. Once i have the pump running correctly I will add my salt. My question is: should i add any bleach or stabilizer to the water since it is getting going for the first time?
    -I have the intex ultra 20x52
    Thanks again!!
    24x54 Saltwater 8000 (thepoolfactory), Hayward 23" Sand Filter, 1.5Hp 1-Speed Power-Flo Matrix Pump, AQ-TROL SWG, AquaBot Pura 4X
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My pool thus far!!
    Sound like you are on top of your project!
    Quote Originally Posted by thedarktitan
    Both. Add enough bleach to get up to ~3 ppm FC then add enough cya to an old sock to get to ~30 ppm and put it in front of the return.
    Do you have an appropriate test kit?
    No. I was going to go pick up one at walmart when I get my bleach and stabilizer.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Some of the better drop based test kits sold at Wal-Mart are good enough to manage a seasonal pool that you plan to drain at the end of the season IF, and it is a BIG IF, If you carefully measure and keep track of what you add in and IF you stay on top of it and nothing goes wrong. However we generally suggest getting one of the suggested test kits, like the TF-100 (or at least the TF-50) available in the link in my signature.
    Ike
    Feb 2008
    Denton, TX
    5,061
    Some places add copper into the mix because it inhibits the growth of algae to a degree. You'll find copper in almost all mineral systems and in chlorination tablets that are made by HTH/Pace. Here at TFP though, we know the damage that copper can do and we also know how to avoid algae without it (by proper chlorination). So, what you are doing is correct.
    Am i doing something wrong?
    -the pool is above the lower inlet, but not the outlet. I figured i could go ahead and start backwashing. I do exactly as the manual states but nothing is happening. The pump is on but it is not sucking any water in??? Am i suppose to let water be above both inlet and outlet? Am i supposed to take the cap off of the drain?
    Nevermind I figured it out. The only issue I'm having now is the inlet that shoots water out is leaking. Although its leaking on the inside of the pool should it be a problem?
    Mar 2013
    Oklahoma
    25
    Our outlet has a minor "jet" from the threads too. It seems like the threads do not seat/seal very well and there's enough pressure to cause the water to seek alternate means of escape.
