Thread: OLCT test
    OLCT test
    If the olct test is 0.5ppm , cc at 0.0 but water is still a little cloudy ( sand filter) can I stop shocking. Really
    sunny this last week and burning through a lot of bleach (6 to 8 liter/day)
    Thanks
    Jun 2012
    Howell, NJ
    977
    Re: OLCT test
    The shock process is finished when:
    1) CC of .5 or less
    2) OCLT of 1 ppm or less
    3) Pool is clear.
    So no, you should keep shocking. Have you tried adding DE to your sand filter? There is a link in pool school somewhere.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: OLCT test
    ^^^what John said^^^
    and, what is the CYA level?
    It would be helpful if you add your pool and equipment info in your sig.
    You're done SLAMing when:
    Re: OLCT test
    cya level is 30. I'm impatient. Losing 1/2 to 2/3 chlorine to the sun just hurts. Thanks for the encouragement, I will to continue to shock. When I think about it, the pool has come a long way from a thick, smelly swamp to partially cloudy in 9 days. Yes I'm also using DE when I'm home for a few hours. Thanks to everyone who contributes on this site.
    Feb 2008
    Denton, TX
    5,061
    Re: OLCT test
    Just be sure that you are running your pump 24/7 during the process. Filter time cannot be underestimated in this process. You're doing good!
