Thread: Jandy AE-TI 2500t heat pump flow requirements
    Hey. New to this but does anyone know the minimum gpm for this heat pump. I just installed a new Jandy stealth 1.5hp 2 speed pump and I want to operate it on low speed but I cannot locate the minimum safe gpm in my manual or anywhere for my heat pump. Thanks in advance for any help.
    18x36 Ingound vinyl Liner
    25000 gallons
    Jandy Stealth 2 speed pump
    Jandy 340 Cartridge Filter
    Jandy AE-TI 2500T Heat Pump 118000k btu
    Intermatic PE153 Digital
    38,275
    Re: Jandy AE-TI 2500t heat pump flow requirements
    Welcome to TFP!!!
    FYI, Generally heating is more efficient at higher flow rates.
    There should be a low flow switch in the heater, you could simply try it on low and see if it operates ... likely it will, but will not transmit as much heat to the pool.
