Results 1 to 7 of 7
Thread: New to forum, but not new to BBB.
    Edited to add photos.
    Thought I'd say hello. I lurked around a lot at the Pool Solutions site and now I'm here. I switched to BBB about two seasons ago. We have been so successfull using it that we are considering an inground pool. Anyways, looks like you all have a good thing going here. Hello and happy swimming.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Welcome Les! Above ground, or inground, the principles are basically the same. If you can handle one, you can handle the other.
    Either way, we'll be here to help. 8)
    Don't forget to share some pictures!
    [Edit] Very nice. Would you mind if I add your pool to the slide show on the home page?
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Les and welcome!
    Nice pool and yard! Beautiful water!
    Glad you are here.
    You're done SLAMing when:
    SeanB's Avatar
    Mar 2007
    2,622
    Looks like you added some pictures.
    TFP Founder
    Hey Sean, I don't mind if you add the pictures to the home page. That'd be neat.
    SeanB's Avatar
    Mar 2007
    2,622
    I'm at work tonight, but I'll put in in tomorrow evening when I have ftp access.
    Thanks!
    TFP Founder
    Very nice... Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
