Thread: Question about graduated cylinders
    Aug 2010
    Columbia, SC
    96
    I have accumulated a fairly complete test kit and am curious as if there is any problem using the same graduated cylinder to perform all the different tests that I do. I have a kit that tests Chlorine, Bromine (Using MPS removal drops), TA, Calcium hardness, Salt, and phosphates all using drop tests with graduated cylinders. Should any of these be done in a separate cylinder?
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Question about graduated cylinders
    Well, the FASDPD test tends to discolor the cylinder but other than that it shouldn't matter really. Rinse really well between tests. I use the same one that came with my speedstir for a lot of the tests..
    Feb 2008
    Denton, TX
    5,061
    Yep, just keep the FAS-DPD one separate. As long as the graduations are accurate, there should be no problem.
    Aug 2010
    Columbia, SC
    96
    Is it just an issue of discolored cylinders with the FAS-DPD? There is no interference with the other tests if I use the same cylinder and replace it periodically?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by kgriggs
    Just rinse them between tests. I have accumulated enough vials and stir bars so that I can run all my tests before I have to do the dishes.
