Become a TFP Supporter Pool School
Results 1 to 8 of 8
Thread: Heater Making Knocking/Tapping/Clicking sort of noise
    Senior Member
    Mar 2007
    Morris, IL
    477
    Why would my heater make this sort of noise? The first year it didn't, but last year and now this year it has. It only does it when it is actually heating though. To me, it sounds like expansion contraction issues. Sort of like an engine cooling down. Only this is different. I need to pull the cover off of it and fire it up to see if anything is visibly making the noise though.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Scale formation inside the heat exchanger is one possible source for that type of noise.
    Are you able to tell what part of the heater the noise is coming from? If it is coming from near the header (where the pipes go into the heater) then it might be a problem with the auto bypass.
    What type of heater is it?
    Senior Member
    Mar 2007
    Morris, IL
    477
    Sorry, it is a hayward 100k BTU heater.
    steve
    Is the heater working normally for you? By that I mean is it heating the water.
    If you put your hand at a return line when the heater is running, is the water warm? hot? same as pool water?
    Senior Member
    Mar 2007
    Morris, IL
    477
    Yes, it is working normally, it heats the water without any problems.
    steve
    Senior Member JasonLion's Avatar
    37,891
    I wouldn't worry about it. Metal expansion and contraction from varying temperatures will make some noise.
    TFP Admin. Creator of PoolMath and Pool Calculator. Other handy links: Support this site, TF Test Kits, Pool School
    Quote Originally Posted by sevver
    If you had a problem you would normally see a slowing of heating. If the heater bypass is scaled up or broken, you will get that clicking noise. The bypass is mechanical and is supposed to open in relation to the water flow to allow the right amount of water to pass through the heat exchanger.
    If you look at a diagram of your heater you'll see the bypass is basically a spring with a disc attached. If it keeps up and it concerns you, I would open up the bypass and inspect the spring and disc (with system turned off). You just want to see if you can push the disc in and that the spring will close it.
    Senior Member
    Mar 2007
    Morris, IL
    477
    Thank you, I have the manual and I will check it out this weekend.
    steve
