Results 1 to 14 of 14
Thread: whistling raypak digital heater
    Our raypak whistles fairly loudly after startup.
    The noise seems to come from the upper half of heater. Whistling sound changes volume if I lower speed on my intelliflo pump. I have a gas shutoff just before heater. If I partially close valve the sound is almost gone. When I do that the flame height is greatly reduced (and I assume heating capacity also reduced)
    Any ideas what could be causing this?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: whistling raypak digital heater
    First make sure you aren't bypassing water from the heater thus starving it of water flow. If you have full flow into the unit, then it sounds like a bypass/ unitherm governor issue. It stops making the sound when you lower the gas input because the water isn't being heated as quickly causing it to create steam inside the heat exchanger.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    I am well above the minimum flow of 25 gal / minute on the inside of the panel. Flow is very strong as SWG works fine as well. If I lower flow of pump from 1900 rpm to 1100 the flow detector on both SWG and Heater shuts off.
    What does the unitherm do?
    I also want to add that whistling appears almost immediately after turning on. Before the system even has a chance to really heat up the internals..
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    The unitherm helps regulate the water flow. There is also a baffle inside the header and if this is broken and lodged in place, then you could be bypassing water from the heater straight back into the pool/spa. Flow in the pool will look normal but not enough water going into heater thus creating the whistling sound.
    Paul
    Ok I have called the installer to take a look
    Pool company replaced unitherm
    was silent for day and then returned. I opened unitherm plug and reseated the part. Silent again for couple hours and then whistle returned. Seems like unitherm part doesn't want to stay seated..
    Can I operate heater without unitherm part?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    No, I would not operate the unit without the unitherm. Is it really that loud or annoying? Also, try adjusting the water flow to be slightly less and see if that makes any difference. Might be too much flow. Is there a bypass built into your plumbing by the heater?
    Paul
    strange .. whistling almost stops if I crank the intelliflo to super high.. on low RPM whistling is louder.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    In my first posting to your issue I asked if there was enough flow. If you have too much you can have issues. If you don't have enough, you can have issues. Flow is important.
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    It is difficult to diagnose this over the internet. It sounds like this heater is new. If so, keep calling the builder till it is resolved. If that doesn't work, call Raypak for warranty service. Have the serial number handy when you call so you get it properly registered too.
    Factory Warranty Station for:
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Here is where you can go to find a Raypak rep if in fact your pool company is not a warranty person for Raypak.
    http://www.raypak.com/PoolandSpaSales.aspx
    I do not believe that you need to register anything with Raypak.
    Paul
    So after 6 weeks of the pool company going back and forth with Raypak, Raypak suggested to replace the baffle with a new plastic baffle design they have. Pool company did the repair yesterday. Whistling is probably half as loud now but still present. Only way to get rid of whistling is to absolutely crank up the pump RPM and then it becomes quite faint. Lower the RPM, the louder the whistle. ****.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    I would expect a bit of a whine when on low RPM as the water is heating faster than it can exit. Typical.
    Sorry that you have had this issue but I can assure you, these units are very good and minimal problems. Yours just must be the exception.
    Paul
