Results 1 to 8 of 8
Thread: why liquid chlorine opposed to the 3" tabs?
    Apr 2013
    NW Ohio
    83
    Just curious:
    Cheaper long term? Less harmful effects from the "stuff" in the tabs, etc......
    Or even the granular stuff. Is there a link explain this anywhere?
    Also thos on BBB method can or do you drip any way. Or do you use something like Penatir Inteelichem or hayward sense & dispense. Or is there a cheaper way to go about this?
    FWIW I already have the Pentair Easy touch unit so adding the intellichem is just the cost of the unit at this point.
    I have always used tabs in past w/o issue....thru a chlorinator
    Now interested in the BBB method.
    18x37 Vinyl Grecian (24k gals) 8' Inter fab(la mesa) Diving board w/ waterfall & Led, Pentair Laminars & Intellibrite 5g
    Star Rite System 3 Cartridge Filter, IntelliPro 3HP Variable Spd Pump, Max E Therm 400k BTU,
    Pentair Easy Touch 8 & actuators,...Now looking to BBB
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: why liquid chlorine opposed to the 3" tabs?
    Trichlor pucks, tabs, sticks, etc. all add both Chlorine and CYA, the Chlorine gets used up, but the CYA continues to build and eventually causes overstabilization of the active Chlorine which leads to algae outbreaks, etc. Those rare people that are using Trichlor and never have a problem tend to be those that have large amounts of water replacement (perhaps backwashing an undersized sand filter very often, lots of rain, etc.) and a short swim season.
    This is all covered in more depth in the pool school link in the upper right of all pages here
    Ike
    p.s. I use a chemical metering pump to add liquid chlorine / bleach as a predetermined rate, when the pool is being used more actively I simply turn up the rate knob a bit, when I see the Chlorine level is getting to the high side of normal during regular testing I turn it down a bit. This may sound awkward, but it really only needs frequent (1 or 2 times per week) adjustment during the first few weeks and the last few weeks of the swim season, for the majority of the warm months I may need to tweak it once per month)
    Apr 2013
    NW Ohio
    83
    nice. any links to the type of doser setup you have....
    Kind of like my saltwater tank! I have peristillic pumps that dose ~ 300ml a day of Alkalinity and calcium to the tank, and I check weekly and then just manually add the extra needed.
    I'd love to setup a simple way to automatically drip/add chlorine and then just manually add some extra as needed. Also where do you add the chlorine as I'd imagine you can't add it to the plumbing due to pressure?
    May 2012
    North of Charlotte, NC
    312
    Here is a great thread to read about chlorine injecting....
    http://www.troublefreepool.com/viewtopic.php?t=29652
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Butterfly's Avatar
    South Carolina
    10,045
    Well, as Isaac mentioned, maybe you are one of the ones with the perfect storm to be able to use the tabs successfully.
    As an aside, if you switch (from tabs which are acidic) you will not be monitoring to raise your TA and pH, but will be using Muriatic Acid to lower pH. Having the waterfall will also cause a pH rise.
    You're done SLAMing when:
    My liquid chlorine experience has been a very stable environment my ph never moves off 7.5 and my TA is always 90 and my water has always been borates as well, love the BBB
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    May 2013
    Dallas area
    85
    With all the problems with CYA buildup when using trichlor, i don't understand why they just dont make it stabilizer free. Is it marketing or does it not hold up.
    Anthony
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by aiannar974
    Anthony
    It doesn't hold up. The chemistry doesn't work. If someone can invent a chlorine tab that doesn't contain calcium or CYA, they'll be a multimillionaire from the users of this board alone.
