Results 1 to 8 of 8
Thread: Bleach, Borax supply in Las Vegas?
    Apr 2013
    Las Vegas, NV
    9
    I just moved to Las Vegas and really having a hard time finding Borax and plain bleach (not concentrated or scented). Anybody live in LV can give me a tip on some good sources? I live in SW Vegas, but willing to drive out farther if necessary. I'd prefer a grocery store to a pool store, but anywhere is better than not being able to find it at all.
    11k gal IG plaster pool w/spa (15x28 "freeform" oval), Blue Haven Pools cartridge smartfilter 550, Jandy VS FloPro 2.0hp pump, Laars Lite2 400k BTU gas heater, probably built 2004
    Dolphin Evolution X5 robotic cleaner, TF-100 Test Kit
    38,275
    Re: Bleach, Borax supply in Las Vegas?
    What is concentrated bleach? As long as there are no additives, scents, thickened, etc it is fine to use. Many makers hand switched to 8+% instead of the previous 6%.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Lowes, Home Depot, Costco, Sam's, Walmart...any of them will have suitable bleach. So will pool stores - some even have it in returnable jugs. You'll just need to do some number crunching to decide which is most economical.
    Virtually every Target near Las Vegas shows Twenty Mule Team Borax in stock. Click on the "Find in Store" button.
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    Apr 2013
    Las Vegas, NV
    9
    Ah, Target. Had not been to one here yet. The Target near my house in San Jose (which I just moved from) did not have Borax so I didn't think to try here. The Wal-Marts I have gone into here just had only the tiny new concentrated bleach bottles available, nothing else. I did just pick up a couple of bottles of Kem-Tek Chlorinating Liquid at Lowe's today, I think that will work for the time being. Thanks for the input.
    Apr 2013
    Las Vegas, nv
    11
    Nps (national pool supply?) & walmart both sell 10% liquid chlorine (bleach) for about $6.50 per 2 gal. which is probably the best deal you're going to find. (Leslie's probably has the same deal).
    walmart sells borax but you might have to hunt around, I just cleaned out the one by my house at Boulder Highway and Trop. $3.38 a box.
    Damon
    New owner, first pool,30+ yr old plaster/gunite,15k gal. White quartz plaster (NEW 5/5/13!)Hayward tristar variable pump Hayward pro grid D.E. Hayward h heater LED color lights.
    Jul 2011
    Las Vegas, Nevada
    139
    Sorry, I think I bought all the Borax available in all of SW Vegas.
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    Jul 2012
    Las Vegas
    47
    Go to NPS for the liquid chlorine. They have 2 gal boxes for 4.95 on sale.
    45k gallon plaster, EasyTouch 8SC, Pentair IntelliFlo VS, IC60, Hayward SwimClear C4020, SwimQuip 1M divingboard, Polaris ATV
