Chlorine test with Taylor K-2006 Kit
May 2, 2013
75
South Florida
Tomorrow I will do my first tests with my kit. A clarification please. It talks about viewing the test water as it turns from pink to clear. The front of the test tube is somewhat frosted, but the back has little Windows that are clear. Am I correct that I view the solution thru the little clear Windows while swirling and using the drops to turn the water to clear, or do I view the solution from the front thru the frosted part of the tub. The instructions don't tell which way. Thank you, John
Apparently I may not be familiar with what comes with that kit. It sounds like you are describing the tube to test the pH? If there not a separate tube for the FAS-DPD test.
The FAS-DPD test should be viewed through clear tube, not frosted.
Posted from my Droid with Tapatalk ... sorry if my response is short ;)
