Results 1 to 8 of 8
Thread: What kind of bug is this?
    Aug 2007
    Austin, TX
    343
    Just saw these little guys in the pool today. Never seen them before and they seem to live long out of the water too... Do I need to look at killing these little guys or will nature rid me of these guys in due time? Are they of any threats to us?
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Mar 2007
    Morris, IL
    477
    It looks like some sort of water boatman. If I remember correctly they are hard to get rid of too. I don't remember how they had to do it. I think it took an unbelievable amount of chlorine.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    These critters are called "water boatman" I believe.
    http://en.wikipedia.org/wiki/Water_boatman
    [i][color=#BF0040]27' x 52"....1.5 HP hayward pump 200lb sand filter.....finally building our deck :)
    Aug 2007
    Austin, TX
    343
    Wow, you guys are fast! Where do they come from and will they die off in time?
    Mar 2007
    Morris, IL
    477
    Probably fall off of birds. I don't know if they will die off. Do you have alot of them? If you have an infestation of them it could be a problem, although I don't remember exactly how it was solved. I just remember someone put one in a jar and tested chlorine amounts to kill it and it was alot. The discussion took place at the other PoolForum though.
    steve
    from what I have read they eat algae. I read about using Bioguard algaecide and keeping your chlorine levels up to prevent algae growth.
    http://wiki.answers.com/Q/How_do_you_ge ... _in_a_pool
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Didn't we find that borates do them in? Or at least run them off?
    Butterfly's Avatar
    South Carolina
    10,045
    If you use the search feature and just enter "boatman", your thread and three others are there waiting for you!
    And they got pix!
    You're done SLAMing when:
