By keeping the chlorine at shock value until it kills the organics. It will, you just need to keep your chlorine up until it does.How do you fight something you can't find?
Probably.Lisaheidinger said:But with guest coming tomorrow...shouldn't I wait now till Monday?
Well, the highest number on the chart is 39 and the highest number for a CYA of 80 is 31 ppm.According to the chart....I would have to bring my FC level to over 50!
[url]http://www.troublefreepool.com/solar-blankets-and-algae-t58854.html[/url]
The comments about +/- CYA test is a general comment that is applicable to anyone who does not feel the shock level is working. If testing and dosing are being done correctly, then maybe the CYA test is off a little bit and the shock level needs to be upped a little to compensate.Lisaheidinger said:Butterfly said I should shock to mustard algae level because my CYA reading could be off by up to 15 point and that maybe I'm just below the required shock level.....
Um, not exactly. Richard said :Lisaheidinger said:...And the chart has a star next to it that says those levels are not practical...?
Well, at 10K gallons, your pool is relatively small and you have a SWG (that requires high CYA), your culprit is invisible, and you appear (in my mind) to be close to winning this battle, so I felt that it was a practical suggestion. I also suggested that you do it at night. That way you get the best bang for the buck.Richard a/k/a chem geek said:..but at high CYA levels it may be impractical to use such high FC levels
harleysilo said:The real question is if you don't do what you've been doing, what are you going to do? What is your pool store telling you to do?
