Thread: Reading Numbers
    Apr 2013
    South California
    69
    Reading Numbers
    I've seen people posting the certain numbers FC, PH....Does your kit show exact numbers or you estimate? I have Poolmaster 22260 Basic 5-Way Test Kit. On chlorine tube, numbers are 5, 3, 2, 1, 0.6. Does your kit says 4.6, 0.8 or 2.5.......you estimated?
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    38,475
    Re: Reading Numbers
    The only really estimated numbers are pH and CYA. All others (FC, CC, TA, CH) you count drops until a color changes, so they are in even increments, usually 0.5ppm for FC and CC, and 10ppm or 25ppm for TA and CH.
    The pH still requires matching colors ... and the CYA you have to determine when a dot disappears.
    You are using a DPD or OTO chlorine test ... we recommend the FAS-DPD chlorine test due to its accuracy.
    Apr 2013
    South California
    69
    Re: Reading Numbers
    I am pretty new with the pool stuff. This is the kit I got. To test Chlorine, I drop 5 drops in tube first and look for the color to match which numbers, not dropping one by one to see color change.
    http://www.amazon.com/Poolmaster-22260- ... B00107039U
    Installed 4/29/13
    38,475
    Re: Reading Numbers
    That is the OTO test ... not very good at getting exact FC or CC numbers.
    See link in my signature for the kits we recommend.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Reading Numbers
    We get the FC level accurate to either .5 or .2 depending on the sample size, using the FAS-DPD test..
    [youtube:8le91r6j]PHQG4tgQsFE[/youtube:8le91r6j]
