Thread: New home own with a pool
    Mar 2013
    South Windsor ,CT
    22
    Hello everyone
    Just opened my pool with the previous own of the house I bought.
    It was crystal clear , did some vacuuming and got it all stirred up .
    My test results are
    TF100 sponsored
    Fc=0
    Tv=0
    At 80
    Ch 220
    My CYA I'm unsure of didn't lose the dot with the test kit
    Pool store registered 30
    Previous own used pucks, I thought it would run higher
    Pool size 21000 gal IG vinal
    South windsor , Ct
    All sun all day
    Jacuzzi sand filter
    Pool 1989
    Liner 2004
    I'm looking to join the BBB club so I was wondering what's next .
    I added 16oz bag shock , I used that instead of bleach due to low CyA level
    I'm also interested in what robot I should get with a 1200$ budget
    Thanks 4 the input
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    Jandy aquapureIE SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New home own with a pool
    What is pH level?
    Did you retest FC & TC after adding chlorine source?
    Welcome to the forum
    You're done SLAMing when:
    Mar 2013
    South Windsor ,CT
    22
    Ph 7.2 have not retested wanna give it an hour or 2
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
