Results 1 to 8 of 8
Thread: Will this PB step up to the CRACK?
    May 2012
    Flower Mound, TX
    130
    Haven't enjoyed the pool yet because of cold weather, but been enjoying the spa a lot.
    BUT, notice loosing water in a 24 hr period. PB said it would be the skimmer or light. So he sent a diver to the pool, and found a crack, approx. 30" on side of wall. OUCH, didn't see that coming after all the homework I put in to find the right PB.
    He's going to send his gunite people to the pool and look at it? The pool is only 2 months old.
    My Question, what is the proper way to handle this? From me and the PB?
    Didn't see this one coming, any suggestions would be helpful while we are waiting to hear from the PB.
    Thanks, John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Re: Will this PB step up to the CRACK?
    Do you have any pictures?
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    May 2012
    Flower Mound, TX
    130
    I will take some today
    May 2012
    Flower Mound, TX
    130
    I will take pictures when I get off work, just got done talking to the PB on the phone. He is sending his workers out beginning of next week and take a look. Also he said they will probably put epoxy inside the crack. I guess they do that underwater? And then we will monitor it, if the leak stops they will mix the plaster to make the same color for the patch work. He seems to take care of the situation.
    May 2012
    Flower Mound, TX
    130
    Crack is where its curving (in the middle)
    Bottom of Tile to top of return
    crack continues to bottom from left side of return (about 30")
    PB says he will fix it
    May 2012
    Flower Mound, TX
    130
    PB is taken responsibility to fixing this pool
    May 2012
    Flower Mound, TX
    130
    I really don't know if the plaster (diamond brite) or the gunite is cracked? I'll soon find out early next week.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Beautiful pool! Terrible Texas star! No idea how or why you would get a big crack in your shell like that, did they put dye in that area to watch it get sucked out crack? This sucks I hope a fix can be done properly and permanately, and would expect that in writing...
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
