Thread: first time testing with tf-100
    Apr 2013
    Port St. Lucie Florida
    55
    When testing for CC.... i put the 5 drops in mixing while adding. it did not turn pink and I did not immediately dump the water. I went on to complete another test and when I looked again at the cylinder the liquid not had turned a slight pink. Question.....how long am I supposed to wait after adding solutions and mixing before reading results?
    Lisa
    10,000 gunite pool
    Cartridge filter
    15,000gal. Free form aggregate finish with raised spa with spillover to pool
    Sta-right Posi-clear 95sq.ft. Cartridge filter
    2hp whisper flow pump
    Pool pilot nano SWG
    Aqua therm heat pump
    22,553
    Re: first time testing with tf-100
    You should read the test within a few seconds of adding the drops. It's common for the test to turn back pink after a little while. Don't worry about it.
    38,521
    Welcome to TFP!!!
    Like Bama said, if you leave it sit, it will turn back pink.
    Here is more information about the tests:
    extended-test-kit-directions-t25081.html
