Thread: Low salt / generator will not turn on
    Brand new to all this maybe someone can help ? My hayward is reading low salt but when I test its at 3400 so the generator cell won't turn on? The pool place said the water temp has to be at 71 degrees before it starts! Well it got that warm two days ago and did not turn on! What do I check next? Cell is only 1 yr old thanks for any help
    22,553
    Re: Low salt / generator will not turn on
    Welcome to TFP.
    Which model do you have?
    Most swg's start working at about 60F. Some lower and some higher but that's about the norm.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Hayward aqua something?
    38,520
    AquaRite or AquaPlus? It should have been working well below 71.
    Low salt can be a sign of the cell needing to be cleaned or going bad.
    I would inspect it for scale and if looks clean, I would suggest taking the cell in to be tested.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Aqua plus , cell is one year old and no scale or dirt. Could it be a bad sensor? The reason I ask is my temps are all reading 10 degrees high
    Jul 2011
    New Caney, TX
    7
    I had the same issue with my pentair SWG. Just over a year old, so still under warranty. They came out and replaced the flow switch.
