Results 1 to 13 of 13
Thread: Why chlorine injection
    Why would one go with chlorine injection over SWG?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Why chlorine injection
    There could be any number of reasons, here are a couple, less worry with corrosion without high levels of salt in the water, no need to add another thing to test for (salt), and then of course there is the issue of no expensive failure prone cell to replace, sure pumps have moving parts that need to be replaced from time to time, but they tend to be cheaper than salt cells, and often fail more gracefully giving some warnings before they outright die.
    Ike
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    No wiring.
    And if you regularly drain water to lower high CH or whatever, you don't have all that salt going to waste and killing the lawn.
    At least that's what I figure. I'm out on the patio several times a day smoking anyway, so sloshing some bleach in manually isn't a big distraction.
    Is it easier to control the chlorine levels for seasonal adjustments and bather load over a SWG?
    30,432
    You can make QUICKER changes to your FC with liquid chlorine but it's not any easier.... turning up the percentage on an SWG is about as easy as it gets.
    From what I have read I cant understand why more pool owners don't use this system. SWG seems so complicated. You guys have me considering a new project. How long does a SWG cell last in a seasonal pool (5 months)?
    A SWG cell will typically last three to five years, longer if your oversize the SWG or have a short pool season.
    There are just as many advantages to having a SWG, you simply didn't ask for them
    what are the advantages and disadvantages of of both systems?
    SWG has no carrying of bleach/liquid chlorine. Salt improves the feel of the water. SWG systems are readily available and fully supported. Chlorine injection systems are not generally packaged for residential use. SWG has better integration with an automation system, for example turning down the chlorine feed rate when switching to spa mode and providing for remote adjustment using some remote control systems.
    I might be wrong, but I thought some people have posted possible warranty issues if a SWG is used.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    tcat's Avatar
    May 2012
    Austin, TX
    731
    More info here: bleach-vs-swcg-t58580.html
    I only spend about $200/yr on Clorox, and can't see the value in more equipment, something that needs replacing every 3 years, possible salt corrosion, at the same or greater cost (salt, recurring equipment cost, & electricity). I have a fairly shaded pool, so that probably makes Chlorine more cost effective (and less work).
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    May 2012
    North of Charlotte, NC
    312
    Turning up the dial on a Stenner injection pump isn't so tuff either
    And some folks, especially my better half don't like the salt feel,taste in the pool...I know I know you should not be drinking the water.... but we've been in a few salt pools and I can always taste a slight residual of salt when swimming?? Maybe the few pools we've been in has just had high salt levels?? But I LOVE my BBB liquid Chlorine ool
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    SWG is probably the easiest system and requires the least amount of work. You still have to test of course, but you can go away for weeks and be assured that your pool will maintain FC levels. One minor problem is that the pH will keep going up so you will have to add acid quite often which can impact how long you can leave with no maintenance. Our neighbors added acid every couple of days. One major problem is that if you have natural stone vs. concrete the salt will eat the stone, sometimes within just a few years. Poolbuilders here will not install salt systems with natural stone. One of our neighbors had to have all their flagstone coping replaced.
    Chlorine injection is pretty easy, but not as easy as salt. You have to add bleach (15 gallons) to the tanks probably at least every 3-4 weeks. We take 4-6 week vacations so need to recruit someone to fill the tanks while we are gone.
    The costs are about the same, but with SWG you pay upfront, with bleach you pay over time.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
