Thread: CH in a vinyl liner pool?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I found a 50lb bag of Calcium Chloride at the local hardware store on clearance for $5 so I bought it. I have a vinyl liner pool and my CH is around 50. Along with everything else this gives me a CSI of -1.17.
    Is there any real benefit to adding it to the pool as far as corrosion goes or should I just keep it for the sidewalks in the winter?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Feb 2008
    Denton, TX
    5,061
    Re: CH in a vinyl liner pool?
    No real reason to add calcium. You control the CSI in other ways. What are your test numbers?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    FC: 7, CC:0, CYA: 70
    pH: 7.6, TA: 80, BOR: 40
    SALT: 2650, CH: 50
    Temp: 72F
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    There's nothing for your water to erode at, and the metals (for example your heat exchanger) won't erode/corrode until your water is far more negative, for the purposes of a liner pool your water is considered to be balanced.
    That being said there's no harm in maintaining CH levels if you feel it will make you more comfortable.
    Stuart Murray
    Scotland UK
    UK NPPOC
    22,553
    My CH has been zero for years and no noticable effect to any of the equipment at all.
    I never worry about the CSI because I know it's not right. As long as you keep the rest of the chems at the levels recommended here you won't have a problem.
    People put too much stock in the CSI number. It's not nearly as inportant as some people make it. As long as you keep the levels within the recommended ranges your pool will be fine.
    30,432
    Listen to bama!! CSI is almost never needed to even think about UNLESS you have some special issues which don't allow your chemistry to be within the guidelines we suggest.
    A little out of contrariness , I have never calculated it for my pool and don't intend to.
