Results 1 to 9 of 9
Thread: How to drain pool?
    How to drain pool?
    [attachment=0:3n9acfo6]phpKwC57RPM.jpg[/attachment:3n9acfo6]I just purchased a new home with a pool and we had a huge rain storm yesterday. It literally rained all day and night. I believe the water level is way too high as it's covering the filter intake completely. I think I need to lower the water level by at least a couple inches. I've attached a picture of my setup. Would greatly appreciate any advice and thanks in advance.
    38,475
    Re: How to drain pool?
    With your filter you do not have a multi-valve that would allow for you to drain to waste.
    I think you can open the drain on the filter and maybe hook up a hose there to then pump out the water.
    Or you could replace the 90 degree fitting that turns down after the pump with a T fitting and in the open end put a spigot valve that would allow you to hook up a garden hose and drain water off that way.
    Do you have a place in the yard that is lower than the pool level? If so, you could just use a hose to siphon the water out.
    There's a opening on top of filter where the water should come out. I just don't know how to release the water. If I turn the valve it just releases the air.
    EDIT:
    Do I need to turn the filter on while the valve is open?
    38,475
    Ummm ... yeah the pump would have to be on to force the water out of the top of the filter (with the pump off, you are allowing air INTO the filter and the water to drain back to the pool).
    BUT, I do not think you want to spray that much water all over everything ... I suppose it will work, but pretty slowly.
    Thanks...that worked great!
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Don't see a backwash line for the filter, think I would of opened the inline feeder lid and let the water drain from there as it can be controlled
    Stuart Murray
    Scotland UK
    UK NPPOC
    Where is the inline feeder?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It's the cylindrical thing behind the left valve in your pic.
    Understood. Thanks. May try that next time to see how it works in comparison.
