Thread: Super large Pebble tec residential Robotic pool cleaner
    I have a 65,000 gal "L" shaped pool. It is about 65'L x 35'w x 8'D the deep end being in the Paw of the dog leg. the finish on the pool is pebble tec and it currently has a navigator that is just not cutting it. I am thinking of replacing it with a Robotic cleaner.
    Are there any issues with these cleaners on a pebble tec finish?
    Any recommendations on makes? I have been leaning toward a dolphin but would like to hear from people with a tiger shark and what kind of service and longevity should I expect. Also how long do you think it should be left in the pool and how often?
    Caddy and remote are a must.
    Thanks
    Dan
    Silver Maple Leafs
    The Royal Canadian Mint uses the finest coin blanks in producing these coins,
    wherein The Canadian Silver Maple Leaf is used as the standard by which all
    the other silver coins are measured.
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Re: Super large Pebble tec residential Robotic pool cleaner
    Just stay away from the barracuda suction powered cleaners....there have been several reports of those not being nice to pebble tech. In your case, I'd recommend a dolphin robotic....aquabot would also likely work....the high quality robotic cleaners usually have a choice of brushes....just call the manufacturer and ask which brushes have been tested against pebble tech for the particular model robot you are purchasing. Usually there will also be a brochure that you can download with pictures of the various brush choices...you should quickly be able to get some confidence that you are making the right order.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    30,421
    To clean 65k with a robot, you have to get one of the smaller commercial ones. Probably $1500 and up. Anything less and it will have to run many, many hours daily to keep up. My pool is 42k by comparison and the $1000 - $1400 robots are BARELY adequate.
    I have only had my Aquabot for two weeks, but no problem on my pebble tech finish. One of the reasons I went with Aquabot instead of Dolphin was because I have a pebble tech finish. The Aquabot has two small water jets that are supposed to dislodge stubborn dirt. It seems to be working. I get a lot of dirt out of the pool when it's done.
    Thanks Great points. I'll look closer at the aquabot and check on the brushes. Ant more feel free to add.
    Dan
    Silver Maple Leafs
