Thread: Solid red PWR light on Intellichlor IC20
    According to the manual, this means you need service. According to Pentair, this means the unit's failure is imminent, but it's been that way for six months and it's still making chlorine. Has anyone else had the same experience? Or has anyone else ever cured the solid red power light?
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Solid red PWR light on Intellichlor IC20
    It has exceeded its designed operating life but it doesn't mean it is not able to operate still. It's telling you that it may stop working correctly. See link below.
    pentair-ic-20-power-light-red-t39337.html
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Just as a side note...if (when) it quits you should consider a IC 40. It can generate more and cycle on less and in theory, will last longer. By the way, how old is your cell? Is the red light being on a premature condition or does it probably have 10k hours on it?
    Bought the house last winter and the cell was there so I don't know how old it is. My guess is that it's dying early, because every other dang thing in the house is dying early.
