Thread: DE in Sand Filter
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    DE in Sand Filter
    Hello
    Can I add DE to my sand filter while I'm shocking to help clear up the pool
    Or should I wait till all is balanced
    My test kit will be here Friday and I've been shocking since Monday
    The pool is blue but very cloudy (way better than green)
    Also is it ok to run the pump on low speed for 22hrs and then on high for 2hrs while I'm shocking
    I hope so that's what I've been doing guess I should of asked sooner
    Thanks
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    22,544
    Re: DE in Sand Filter
    Yes it's ok to add DE to the filter while shocking. Just be aware that it's going to clog pretty quickly depending on how much "stuff" is still in the pool.
    And yes it's ok to run the pump on low. It will clear faster on high, but it's fine to run on low.
    38,271
    I would not bother until you are sure everything is dead and ready to be filtered out.
    That should be fine with the pump speeds as it keeps the water circulated.
