Thread: SWG and Aluminum Pool
    Feb 2013
    Worcester, MA Suburb
    53
    Hi.
    Sorry to start another thread on this topic, but most of the threads I found involved "steel" pools, not aluminum ones, like mine. I have a brand new 24' aluminum Premier Collisium pool (formerly Esther Williams). It is 100% aluminum - walls, extruded rails and plates.
    Can I use a SWG system safetly with my pool? The warranty actually calls out "steel" pools specifically, but does not mention aluminum. Here is a quote from the warranty sheet:
    "The present warranty does not cover the following:
    f) Damages caused by the utilisation of a salt water chlorination system in combination with a steel pool structure (top ledges, uprights, joiner plates, wall channels)."
    What do you think? I also have an AquaComfort heat pump, but that uses a titanium exchanger, so should be OK.
    Dino
    Premier (Esther Williams) 24' x 52" Round AGP (13,500 gl.), Hayward 24" Pro-Series S244T Sand Filter, 1.5 HP Hayward Super Pump, AquaRite SWG, AquaComfort ACT-1100 Heat Pump, Jandy/Zodiac iAqualink Automation System with iPhone App, Aquabot Pool Rover S2-40
    My New Pool
    22,543
    Re: SWG and Aluminum Pool
    There are very few problems with steel pools and an swcg, so and all aluminum pool should fair much better. If you're concerned about the warranty, I'd call or email them and ask that specific question and see what they have to say.
