Results 1 to 11 of 11
Thread: How long can a pump run 24/7 safely
    Oct 2007
    Lafayette, La
    39
    I have been addressing an algae problem. My pump has run for the last 4 days solid. My husband is having a fit and wants to put it back on the timer. Is there an amt of time to run the pump after which you should turn it off. My gauge reading is always 12-15 and that is where it has stayed during the last 4 days.
    It is fine to run the pump 24/7. The only issue is that it uses more electricity and so costs more than running it less. A fair number of people run their pumps 24/7 for the entire swim season, months at a time.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    A few days or week is nothing to the pump. It doesn't rest overnight, so hours are hours. Some people run their pumps continuously all season long. Mostly people who have waterfalls or other water features, but it is no big deal to run 24/7.
    actually a pump is similar to a car. the more you turn it on and off the shorter the life of it will be. Your pump will run much longer the less it is turned on and off. True Story.
    Oct 2007
    Lafayette, La
    39
    Thank you all for replying so fast.
    Apr 2008
    Central Texas
    326
    My next door neighbors pump is just over the fence from mine. It's been running for almost 2 years that I know of...
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Just don't forget to check and make sure it has enough gas in it. They don't use a lot of gas but it will burn it up pretty quickly if you do run it all the time.
    Gas? Almost all pool pumps are electric.
    Mine runs on vegetable oil.. I am going through liners like crazy!!! :P
    2003 Marquis Euphoria - 400gal
    North Carolina
    19
    As my husband always says "motors are plugged in ...engines are not!! " He gets really disturbed when NASCAR drivers talk about the "motors" in their cars.
    So maybe there is now an engine for pools, using gasoline?????? LOL :P
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    Sep 2007
    N. AL
    65
    I run my pump 24/7, we have deck jets, a water slide and a heat pump that will only work when it is on. That and my hubby won't agree to not running it all the time.
