Thread: Polaris Booster pump quick connect replacement
    My polaris PB4 quick connect broken off from the output pipe. I saw the replacement part but I am confuse whether i need to change the whole quick connect or just the oring that attached hose to the quick connect please see attached pic. Do i have to ungule / cut out the quick connect to install new quick connect?
    Re: Polaris Booster pump quick connect replacement
    One more pic
    Apr 2011
    Warner Robins, GA
    245
    Are you sure its broke? If I recall (its been a while) yours looks fine....slip the nut from the hose back, push the hose over the nipple and just tighten the nut. The nut doenst thread into anything but rather catches on the hose and acts like a compression ad hoq connecton.
    I dont ever recall the red pull offs to do anything at all.
    I am farily certain, but it has been a while.......
    Other input?
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    Apr 2012
    151
    JH Jr is correct, but has it reversed....
    Slip the nut off the hose and onto the "nipple" of the connection. Make sure it is oriented correctly - look at the other one in the background. Then, you might want to cut a little off the hose to get to "virgin" hose, slip it back on the nipple with the nut sitting at the bottom. Then the nipple slides up onto the hose. The red retainers are to keep the nut from slipping down and letting the hose loose, causing a "flying hose, pool draining dance" while the pump is on.
    Clay
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Apr 2012
    151
    Oh, the red retainer has to be off till the end or this won't work....
