Results 1 to 10 of 10
Thread: Northern Solar Questions
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    What is the weight of a standard 4x20 solar panel filled with water? I live in Michigan and I believe I could fit 4 panels on a section of my roof. What average sort of Temp increase would I see on say a 80 degree day?
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Northern Solar Questions
    I don't know the numbers for a 4x20, but a 4x12 is 64 pounds for the TechnoSolis panels I have, other brands seem to be in the 55-68 pound range. Of course some of that water is in the headers so I would guess a 4x20 would be in the 100 pound range.
    Ike
    38,260
    I think 100 lbs is a good estimate ... really not very significant as far as weight goes.
    Impossible to guess how much temp increase you will get in a day ... too many variables.
    That would be 320 sqft of panels. How much surface area do you have on the pool? Do you use a cover? What direction is the roof facing? How windy is it? Also the air temp is not quite as important as the amount of sun. And on and on ...
    Just get what you can fit and live with the results ... a cover will make a significant difference to how much heat is retained.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Pool is 512 sqft
    I have a 12 mil cover
    Roof has a slight angle east
    not very windy
    I would figure maybe a 40 degree increase on a cloudy day..................
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Quote Originally Posted by pooly1
    I doubt you'd see a 40 degree increase on the hottest, sunniest day of the year.
    38,260
    I would guess you would see about 3-4 degrees on a good sunny day.
    I have no cover, but have 500 sqft on S and W almost flat slope and I have seen about 5 degrees ... then lose most of it at night due to lack of cover ... just depends on how cold it gets and how windy.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Oh wow I was figuring I would be in
    the range of 5 to 10 degrees
    Sep 2012
    Lake Nona, Florida
    386
    A solar cover makes a big difference. It took us about a week to tack on 15 degrees to our pool when the solar was installed, with the cover on and with night temps getting pretty low. Now that the night temps are more moderate we took off the cover and over night will lose 5 degrees or more then during the day get it all back. Today is cloudy and I hear it going on and off - we have only picked up 2 or 3 degrees so far.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    Mar 2007
    Ontario
    211
    We are getting 1 degree per full hour of sun. Around 8 per day lose 2at night.
    Just went over 70 degrees today. Should be swimming on Saturday with the sunny forecast.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    mas985's Avatar
    Pleasanton, CA
    11,737
    The most I have ever seen is 10 degree gain in one day. But the pool started at 78 and it was one of the hottest days (100+) of the year. I have about 80% area coverage.
    Mark
