Thread: New to testing water using Taylor K=2006 kit
    I am brand new to testing my pool water, I have a Taylor K-2006 kit that I just received. I have read that you can use one scoope of the R-0870 powder if the water turns pink with the first scoope....Is it really OK to use the one scoope rather than the two that the instructions tell you to do? Secondly are the scoopes level scoopes or heaping scoopes? The instructions does not day....I call them scoopes, but the insturctions calls them dippers. Any help is very much appreciated....I don't want to penny wise and pound foolish, but don't want to waste the powder either. Many thanks, John
    16100 gallon rectangle pool built in 1984 including a 5' X 5'x 3' Spa, Diamond Brite in year 2000, Non-SWG Pool
    Feb 2008
    Denton, TX
    5,061
    Re: New to testing water using Taylor K=2006 kit
    Welcome to TFP!
    You can use one scoop and it doesn't have to be heaping. All you need is just enough to turn the water pink.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Welcome to TFP!
    I've found that if you have one or two undissolved granules in the pink water before you start adding drops, you have the right amount.
    A very big thank you to both of you......now to.test the water Saturday and see what the rain has done toy pool water....thank you again, John
    Guest
    Having the same question. Thank you for the answer.
