Thread: Transitioning from Modified Bicarb Startup to BBB
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Our pool was built last fall except for the quartz finish (CL Industries SunStone Select Sapphire) which PB did last Tuesday 4/23. When speaking with PB he said the plasterers would do a light acid wash to expose the quartz, I was kinda bummed because everything I read in onBalance's posts advised against it. I tried to talk PB out of it and he said its up to the plasterers, warranty, etc...so I let it be. The plasterers showed up a day early so I did not get to build my 55 gallon drum for the bicarb startup, I thought the whole bicarb startup was going down the crapper. In watching the plasterers I noticed near the end they just washed the quartz finish with a light spray of water from the hose and used a soft bristle brush to expose the quartz. The leftover water was pumped out of the pool. I was happy about that, no acid wash!
    So I decided to add bicarb to the pool after filled, I added 36 lbs of A&M baking soda which took my starting alkalinity from 140 to 230, I also added calcium to increase the hardness to 230, my pH has never been above 7.8 and there is very little plaster dust when I brush (2x per day). The finish looks great and the water is clear. I have added CYA and Bleach to get those levels up.
    What I am curious about is how to I change my levels to transition to the BBB method? According to onBalance's post "A Bicarb Start-up guide for TFP Members" he mentions keep the TA high for a month, do I lower it after that using the "Lower Total Alkalinity" from Pool School?
    Here is a summary of my latest results from my TFT Test Kit
    TA - 230
    CH - 230
    pH - 7.8
    FC - 2.0
    TC - 0.0
    CYA - didn't measure yet because just added
    Pool Volume - 26,000 gallons and a salt pool but I have not added yet
    Before brushing, pool is clear
    Pool is 62F, outside temp is 45F, I'm losing heat!!!
    Clear to the dirty bottom, wish I could vacuum, light shimmering off bottom
    After brushing
    Thanks for all your help
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    38,532
    Re: Transitioning from Modified Bicarb Startup to BBB
    Quote Originally Posted by bigfunky
    Yup. That is the only way to lower the TA. It will drift down due to you maintaining the proper pH, but the process in Pool School, just gives you the ability to drop the TA faster.
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Water is looking great!
