Thread: FC
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    FC
    What happens if FC =24 and your cya =0
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: FC
    Quote Originally Posted by SkyKid
    You'll waste a lot of bleach to sunlight.
    You'll also bleach out a vinyl liner. And swimsuits. But in a couple hours of daylight it should be down to normal.
