Thread: Tests where Speed Stir not recommended?
    Apr 2013
    Phoenix AZ
    20
    I got my Speed Stir the other day and have been using it for all tests in the TF-100 kit. Are there any tests where the Speed Stir is not recommended to be used? I ask because it seems my FC raised when using the Speed Stir even when I didn't add chlorine which leads me to believe that one of the methods produced inconsistent results.
    ~20,000 gal in-ground plaster pool, 3/4 HP pump, ~3 sqft sand filter (newly replaced May 2013), TF-100 test kit with Speed Stir!
    30,421
    Re: Tests where Speed Stir not recommended?
    I use the speedstir for all the tests. Posts from forum members seem to indicate it is more accurate than doing by hand.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I don't use it for the pH or OTO color block tests.
    The stirbar even fits through the mouth of the CYA mixing bottle.
    Apr 2013
    Phoenix AZ
    20
    Alrighty then, glad I got it since I was measuring FC in the 3-4 range without the Speed Stir and now measuring in the 5.5-7 range without adding bleach.....unless the Trichlor (I know, I'm just going to use up the remaining 3-4 I have left) is increasing it that much.
    38,305
    It could be the tablets .... depends on how fast they are dissolving.
