Thread: Pump replacement options
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I have a 1.5hp Pentair Whisperflo, single speed. It's 5 years old, no real problems. I'm thinking of buying a "spare" for when it dies so I can do a quick swap. Can a 2 speed whisperflow be "swapped" without much rewiring effort? I like the idea of running twice as long at half the speed, but don't want to waste the extra $300-$400 for 2 speed if it's not worth it. No water features, and probably getting a robot soon.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    38,471
    Re: Pump replacement options
    You could actually just buy a replacement 2-speed motor ... no need to replace the wet end if it is fine.
    Really a 1.5HP Whisperflo seems like over-kill for your pool. You could replace with a smaller 2-speed motor and a smaller impeller. Or go with a smaller 2-speed pump like the Superflo.
    Is your current motor 115V or 230V? You would need to add a manual switch (there are some motor end caps that have the switch). But, the voltage may affect what motors are available to you.
    BTW, the Superflo comes with a manual switch installed.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Thanks. I'll have to look when I get home. I always thought everything was a bit of overkill. All 2" pipe, 48' DE filter, 1.5 hp... all seem a bit much for a 15K gallon pool. It is about 45' from the pool/skimmer, but that's not that far. Smaller motor = less EE use!
    DIY chlorine feed
    BBB
