Results 1 to 7 of 7
Thread: Spa jets + booster on = increase in filter pressure. Why?
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Please help me understand why this is true.
    To the best of my knowledge, the spa jet pump and booster pump are plumbed separately from the returns and drain. I have 2 drains in my spa: one on the floor and one on the wall. I've concluded that the drain on the wall goes to the circulation pump / filter, and the other goes to the spa jet / booster pumps.
    With the valves set to spillover mode (drain from pool, return to spa), my filter shows 11 PSI (10 PSI baseline when I cleaned the filter last month). When I flip on the spa jets and booster pumps, my filter pressure climbs to 16 PSI.
    How can this be? The only explanation is that the two systems must be connected somewhere, right?
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
    38,274
    Re: Spa jets + booster on = increase in filter pressure. Why
    That is a little puzzling as I too would have thought the systems were independent.
    My initial thought (before reading all your post) was that if the booster pump was fed from the return water after the filter, then that could reduce the main pump pressure side head loss and allow the pump to move more water and give the higher pressure ... but now that I wrote that, I am not sure it actually makes sense. And if you have separate drains for the 2 pumps, then it certainly does not make sense.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Maybe it would help to post a picture of your pad plumbing/equipment.
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    I'd do some experimenting. Turn on the booster alone and see which returns spew water. Also see if that makes the pressure rise on the filter. If yes to either, the returns are teed together and the flow is greater than the pipes can accommodate without the pressure climbing.
    Apr 2013
    SoCal
    120
    Here's the pad and equipment. Sorry about the shade!
    The bell-shaped thing on the stick is the booster pump (which is LOUD! I wonder if there's a problem with it ...)
    The black pump is the spa jet.
    The white pump is the circulation pump.
    I did some testing, and sure enough, the returns and spa jets are plumbed together. I can feel water flowing out of all of the returns in the spa, and when I flip the spa jets on, I feel increased pressure again on all returns.
    Is this typical? Where do you think it's more likely they are teed together? Before or after the filter?
    For what it's worth, turning the booster pump on made no difference in filter pressure.
    Matt
    Apr 2012
    151
    The thing you are calling the booster pump is an air pump for the spa air. There would have to be a water in and a water out for it to pump water. That model is made by Polaris and is a 1.5 HP, 110v model.
    And yes, they are loud. It is a strong fan.
    It would make sense that if it is connected to the spa jets that it would raise your pressure...
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Apr 2013
    SoCal
    120
    Quote Originally Posted by msumoose
    Got it. I just found the product literature, they call it a blower.
    Matt
